A few questions
Hi all, i have a few questions i couldn’t find an answer to:
  1. Is there any estimated time on when the oled optical engines for the crystal super and the hand tracking module will be available to order?
  2. Can the dream air lighthouse version be used without the towers if used seated? I ask because at the current moment i do not really care for the controller tracking or head tracking, but in the future i will likely do. This is because at the moment i don’t have enough space to set up the towers
  3. Would you say it would be worth it to swap from the crystal super to the dream air? And if so, is there any trade in offer to do that?
Thank you for the insights!
Answer 2.
You’ll need at least one HTC or Valve Base station but preferably two. Can be placed anywhere stable like a bookshelf. Mine are bolted to the wall and have cable trunking to hide power supply cable
Answer 3.
Very different headsets. Trade offs for both. You’ll only know after using both. My Super 50ppd is pretty incredible and have a lighthouse faceplate coming soon;)
