Hi my 8KX arrived today courtesy of DHL. Box arrived nicely packed and no signs of damage.
I did a clean install of the latest PiTool (no previous version has been installed on my PC since I last did a fresh clean install of Windows 10) and I downloaded the latest 8KX firmware.
Loading PiTool my 8KX is showing as Disconnected - despite being plugged into my one of the DisplayPorts GFX card and two USB 3 ports on my mobo. The red light is on on the headset itself so it’s for sure got power. When I click on Guide it won’t let me click on “Next” when selecting either USB or power cable.
I’ve tried swapping both the DisplayPort and USBs to alternate ports on my GFX card and mobo but that doesn’t seem to make a difference.
Can’t see a way to update the Pimax firmware in PiTool (at least not without getting PiTool to see the headset first).
You may first try to tips provided from the community.
If it doesn’t resolve the issue, please submit a ticket at our helpdesk.
Our technician will provide assistance to you.
I think I’ve fixed it - I believe it was a driver problem with my USB controllers.
I reset Windows and reinstalled PiTool and it recognised the headset. I also managed (I think) to successfully update the firmware but that process is NOT intuitive (as I had to download a separate program to PiTool and then copy/paste those files into the Runtime folder for PiTool. It would be much better if that process could be integrated into PiTool itself (it even seems to have a function for it, but it doesn’t appear to do anything).
Only had time to briefly try out the Apollo 11 HD experience (native resolution, normal FOV) and I was impressed - no discernible screen door effect. I’m looking forward to trying some proper games when I have time at the weekend.
One thing I will say is that the headset strap can definitely be improved upon - I’m hoping they take the feedback on board (from many places) when they finalise the DMAS design.
Also does anyone else find that they get a little bit of light entry at the sides of the headset - no matter which face cushion they use? It’s a minor annoyance but interested to know if anyone has a solution (other than just clamping the headstrap on even tighter - as that’s likely to get uncomfortable after a while).
