# 8K+ setup of controllers
**URL:** <https://forum.openmr.com/t/8k-setup-of-controllers/28730>\
**Category:** P2: 8k(+)\
**Tags:** 8kplus\
**Created:** [June 23, 2020, 6:18pm UTC](https://forum.openmr.com/t/8k-setup-of-controllers/28730 "2020-06-23T18:18:29Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![DTH](https://forum.openmr.com/letter_avatar_proxy/v4/letter/d/9fc29f/32.png) [@DTH](https://forum.openmr.com/u/DTH)\
**Post date:** [June 23, 2020, 6:18pm UTC](https://forum.openmr.com/t/8k-setup-of-controllers/28730/1 "2020-06-23T18:18:29Z")
</div>
Working on setting up my controllers. I know one end of the USB cable goes into my controller. Do there other ends go into the computer or is that how I charge them via the computer or wall socket with a USB wall adapter?
**Author:** ![Mikenz666](https://forum.openmr.com/user_avatar/forum.openmr.com/mikenz666/32/13012_2.png) [@Mikenz666](https://forum.openmr.com/u/Mikenz666)\
**Post date:** [June 23, 2020, 6:38pm UTC](https://forum.openmr.com/t/8k-setup-of-controllers/28730/2 "2020-06-23T18:38:59Z")
</div>
Can charge from computer USB port. Also used for firmware updating them. Vive or index controller? Probably can use a phone charger unit to charge them if you can plug your USB cable into it
The pimax program should guide you through setup for first use
**Post date:** [August 22, 2020, 7:53pm UTC](https://forum.openmr.com/t/8k-setup-of-controllers/28730/4 "2020-08-22T19:53:55Z")
</div>
