# 144Hz small FOV and 120Hz Normal FOV for Pimax 5K+
**URL:** <https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795>\
**Category:** P2: 5k(+/XR)\
**Created:** [January 30, 2020, 3:28pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795 "2020-01-30T15:28:50Z")\
**Posts on this page:** 14\
**Page:** 2
<div class="post-metadata">
**Author:** ![Virtual](https://forum.openmr.com/letter_avatar_proxy/v4/letter/v/ed8c4c/32.png) [@Virtual](https://forum.openmr.com/u/Virtual)\
**Post date:** [February 7, 2020, 1:28pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/21 "2020-02-07T13:28:34Z")
</div>
How interesting. I’d love to test it myself but I don’t want to risk bricking my headset.
My guess is the framing is different in that FW and PT. Perhaps if you don’t like it you would be better off using the correct versions for your headset.
But it is good to know the FW can be flashed successfully to some non 202 headsets.
You also mentioned a 120hz option which means the PT is correctly identifying your headset as that FW added 110hz to the 202 headset.
Is your FOV the same for 90hz and 120hz in Normal or is it slightly smaller in 120hz?
**Author:** ![bubbleball](https://forum.openmr.com/user_avatar/forum.openmr.com/bubbleball/32/1505_2.png) [@bubbleball](https://forum.openmr.com/u/bubbleball)\
**Post date:** [February 7, 2020, 1:55pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/22 "2020-02-07T13:55:39Z")
</div>
Interesting and I just tested.
120hz normal fov = 90hz small fov
90hz small fov = 90hz potato fov
I am not sure, but I feel that potato fov look better than old 120hz + small fov (I think that it is smaller than this potato fov if I can’t remember wrong).
**Post date:** [February 7, 2020, 5:34pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/23 "2020-02-07T17:34:05Z")
</div>
If that’s the case switch to the correct FW because that’s worse than I have.
For me 120hz normal is slightly smaller than 90hz normal but bigger than 90hz small. The big difference is 120hz normal has flat sides but 90hz normal has round sides. I prefer the round sides.
**Author:** ![Fusion](https://forum.openmr.com/user_avatar/forum.openmr.com/fusion/32/16269_2.png) [@Fusion](https://forum.openmr.com/u/Fusion)\
**Post date:** [February 13, 2020, 9:27pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/24 "2020-02-13T21:27:55Z")
</div>
when will it be available?
**Author:** ![ChrisMinMax](https://forum.openmr.com/letter_avatar_proxy/v4/letter/c/7feea3/32.png) [@ChrisMinMax](https://forum.openmr.com/u/ChrisMinMax)\
**Post date:** [March 9, 2020, 6:54pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/25 "2020-03-09T18:54:54Z")
</div>
How is the 144hz mode?
**Author:** ![PimaxVR](https://forum.openmr.com/letter_avatar_proxy/v4/letter/p/c5a1d2/32.png) [@PimaxVR](https://forum.openmr.com/u/PimaxVR)\
**Post date:** [March 12, 2020, 6:33am UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/26 "2020-03-12T06:33:03Z")
</div>
@Alex.liu
Release the 144Hz mode bata test version in the forums.
**Post date:** [March 12, 2020, 6:45am UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/27 "2020-03-12T06:45:11Z")
</div>
is the 120hz large fov also available ?
**Author:** ![Gonzas](https://forum.openmr.com/letter_avatar_proxy/v4/letter/g/dfb087/32.png) [@Gonzas](https://forum.openmr.com/u/Gonzas)\
**Post date:** [March 12, 2020, 11:44am UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/28 "2020-03-12T11:44:41Z")
</div>
is avalaible?
where?
thanks!
**Author:** ![Godislove4u](https://forum.openmr.com/letter_avatar_proxy/v4/letter/g/5f8ce5/32.png) [@Godislove4u](https://forum.openmr.com/u/Godislove4u)\
**Post date:** [March 18, 2020, 12:52am UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/29 "2020-03-18T00:52:03Z")
</div>
That would be super cool!
**Post date:** [March 18, 2020, 12:52am UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/30 "2020-03-18T00:52:44Z")
</div>
It’s very cool but not exactly aligned with your eyes.
**Author:** ![flynny75](https://forum.openmr.com/letter_avatar_proxy/v4/letter/f/edb3f5/32.png) [@flynny75](https://forum.openmr.com/u/flynny75)\
**Post date:** [March 29, 2020, 2:57pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/31 "2020-03-29T14:57:14Z")
</div>
144hz is not usable for me. There is significant ghosting. There is _some_ ghosting at 120hz. No ghosting at 90hz.
**Author:** ![Malcolm](https://forum.openmr.com/letter_avatar_proxy/v4/letter/m/e19b73/32.png) [@Malcolm](https://forum.openmr.com/u/Malcolm)\
**Post date:** [April 1, 2020, 7:44pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/32 "2020-04-01T19:44:55Z")
</div>
Snap! Lots of ghosting when you move your head around and SS is definitely off.
**Author:** ![Thall](https://forum.openmr.com/letter_avatar_proxy/v4/letter/t/bbce88/32.png) [@Thall](https://forum.openmr.com/u/Thall)\
**Post date:** [April 1, 2020, 7:55pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/33 "2020-04-01T19:55:53Z")
</div>
I have the same issue, 120Hz is fine though. Weird. Others seem to have no problem
**Post date:** [May 31, 2020, 7:55pm UTC](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795/34 "2020-05-31T19:55:55Z")
</div>
[Previous page](https://forum.openmr.com/t/144hz-small-fov-and-120hz-normal-fov-for-pimax-5k/25795.md?page=1)
